axle stands
- jfkenpoman
21 Jan 2013 21:33 #59017
by jfkenpoman
axle stands was created by jfkenpoman
which axle stands did you use when you fitted your 2" suspension kit?
I have seen these on ebay:
thumbs1.ebaystatic.com/d/l225/m/mJMm0fOq1NFBGxvt1FIL7cQ.jpg
wondered if they would do the job, would they be long enough
3 tonnes 300 to 435mm extended length
- TomDK
21 Jan 2013 21:36 #59019
by TomDK
Replied by TomDK on topic axle stands
No eBay APP ID and/or Cert ID defined in Kunena configurationI use these
As I find the ones you linked to a bit too short
- jfkenpoman
21 Jan 2013 21:53 #59030
by jfkenpoman
Replied by jfkenpoman on topic axle stands
cheers mate i have found 2 sets of the same ones you've suggested for £46 with free delivery
- TomDK
21 Jan 2013 21:56 #59031
by TomDK
No problem
But it also depends on how tall your tyres are. I measured from ground up to underside of chassis. I need to jack up chassis 2-3 cm before the stands I bought will fit under, when they are at lowest setting. But this works out great for me, as this means I can raise either end pretty high up with the stands at their highest setting.
- jfkenpoman
21 Jan 2013 22:56 - 21 Jan 2013 22:58 #59046
by jfkenpoman
i am intending to fit bfg 215/75 x15 with black modulars and then later when money permits fit the 2" suspension kit :laugh:
i do have a car jack as well to initially lift suzuki off the ground
Last edit: 21 Jan 2013 22:58 by jfkenpoman. Reason: missed information
Time to create page: 0.173 seconds
