wheel arch extension
24 Jan 2013 22:15 - 24 Jan 2013 22:17 #59463
by Obarno
Replied by Obarno on topic wheel arch extension
Dave - I also used 50 sq mm cable and soldered the lugs on the end. The alternator is standard and the battery is a Varta 650cca. Don't know how well it will all work but its a first event so a bit of try and see. This event is also being run by a Land Rover predominant club, but they don't mind what vehicle you use. It's described as a novice winch challenge and I know the organisers well, so should be a bit of fun. My team mate is my nephew with his Sammi to which he has fitted a big drum Goldfish with a bow 2 motor, so should be a bit over winched compared to mine!
Sorry to hijack this thread with winch info!
Last edit: 24 Jan 2013 22:17 by Obarno.
- TomDK
- Visitor
24 Jan 2013 22:18 #59465
by TomDK
I think you're right
I've only got 30 meters of 10mm fitted. But got it cheap
Saw that want an internal rollcage. Do you make it yourself?
Replied by TomDK on topic wheel arch extension
Dave cc wrote: 150ft of 11mm plasma think that should be enogh to get me out of trouble
Time to create page: 0.135 seconds
