stereo woes !! no sound
  • JerseyJimny
  • Visitor
  • Visitor
19 Jan 2013 13:52 #58647 by JerseyJimny
Replied by JerseyJimny on topic Re: stereo woes !! no sound
Speakers blown? Only way to test is by buying new ones I guess...
Are you sure you have them connected the correct way around if you put positive to negative on a speaker it dosnt work
Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk 2
  • little jimny
  • Visitor
  • Visitor
19 Jan 2013 14:10 #58651 by little jimny
Replied by little jimny on topic Re: stereo woes !! no sound
JerseyJimny wrote: Are you sure you have them connected the correct way around if you put positive to negative on a speaker it dosnt work
That's not really true is it - they just play out of phase.
Have you checked for continuity in the speaker cables? Maybe a previous owner had cut the wires for some reason. Get a multimeter and check this. Even blown speakers should make some sort of noise
  • ohgoon2006
  • Visitor
  • Visitor
19 Jan 2013 16:39 #58663 by ohgoon2006
Replied by ohgoon2006 on topic stereo woes !! no sound
oh thanks guys sorry not really up on the mech side of things how do i do that then ?
many thanks
  • reaper
  • Visitor
  • Visitor
19 Jan 2013 17:24 #58669 by reaper
Replied by reaper on topic stereo woes !! no sound
Get a tester and and put one end on one of the cables at the speaker end and the other on the radio end . You should get a beep from your meter if the wires are not cut
Test all 4 wires 2 left and 2 right , when testing unplug the wires from the radio and the speakers or you may get false readings :-)
One last thing wile you have the wires off the speakers put a 9v pp3 type battery on the terminals this will make the speaker bounce if its working
  • ohgoon2006
  • Visitor
  • Visitor
20 Jan 2013 12:52 #58778 by ohgoon2006
hi there thanks for that how do i get a tester to reach from the speaker port to then reach the radio ?
i wondering if its a wire behind the dash somewhere for it to work once then not again ?
  • little jimny
  • Visitor
  • Visitor
20 Jan 2013 13:42 #58780 by little jimny
Replied by little jimny on topic stereo woes !! no sound
The multimeter will have two probes on the end of a lead. There will probably be enough reach between these two leads to reach - one at the stereo wiring end and one at the speaker end. If there is no continuity (ie wiring cut or broken) then it should be a fairly straightforward task top replace them with some new speaker wire from Halfords or the like.
Time to create page: 0.149 seconds
