Auto gearbox removal g13
- Thank you received: 252
14 Jan 2013 22:27 #58077
by j999pre
Grey pick up Jimny
Auto gearbox removal g13 was created by j999pre
Hi.
Need a bit of help splitting an auto jimny engine aond gearbox.
I have removed all the things I would on a manual jimny. But is the flywheel bolted to the auto box? I can see bolts throuh the hole where the starter was?
Normally the manual gearbox would just pull off. Never done an auto before.
Thanks
Thanks
Grey pick up Jimny
- vitara_mad
15 Jan 2013 00:42 #58111
by vitara_mad
Replied by vitara_mad on topic Auto gearbox removal g13
flywheel is bolted to the engine with the torque converter
im no expert on auto box's but can't see why it should not split from the engine just like a manual
15 Jan 2013 05:55 #58113
by facade
Replied by facade on topic Auto gearbox removal g13
Normally the torque converter comes off with the gearbox, just undo the bolts through the flywheel using the access provided.
Then the torque converter has to be attached and engaged at the gearbox before fitting, because the oil pump drive has to line up to get the converter on far enough. If you fit it to the flywheel then add the gearbox, you can force it on ok, but the oilpump just breaks, and there is no drive.
15 Jan 2013 14:23 #58151
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Auto gearbox removal g13
I thought that might be the case. Presumably I get to the bolts by accessing them from through the flywheel cover plate underneath. Only issue is the engine is dead and may not turn over.
Grey pick up Jimny
16 Jan 2013 22:31 #58336
by j999pre
Grey pick up Jimny
Engine and box are apart
6 12MM bolts undone through the starter hole and apart she came.
Chuffed
Chuffed
Grey pick up Jimny
Time to create page: 0.099 seconds
