Jimny running hot ?
- suzuki jimny fella
- Visitor
11 Jan 2013 20:19 #57772
by suzuki jimny fella
Replied by suzuki jimny fella on topic Jimny running hot ?
pics
- TomDK
- Visitor
11 Jan 2013 23:29 #57784
by TomDK
Of what?
Replied by TomDK on topic Jimny running hot ?
suzuki jimny fella wrote: pics
Of what?
- TomDK
- Visitor
12 Jan 2013 11:15 #57795
by TomDK
So, took the JImny for a quick spin today.
After 5 mins the temperature reading was at about 3/4. So something is wrong.
I'm guessing either pump or thermostat.. Hoping for the thermostat
- VAXXi
- Visitor
12 Jan 2013 11:29 #57796
by VAXXi
The gauge is not very accurate indeed, if you use a Scangauge or similar device you will see the real coolant temperature varies significantly while the needle doesn't budge.
The regular needle position on mine is also a bit under the middle, barely touching the thermometer "dot".
Replied by VAXXi on topic Re: Jimny running hot ?
goatboy wrote: Not sure how accurate the sensors are though so if its only a tiny bit over half its probably fine...
- TomDK
- Visitor
12 Jan 2013 14:41 - 12 Jan 2013 15:32 #57806
by TomDK
Replied by TomDK on topic Re: Jimny running hot ?
I have taken the thermostat out and put it in boiling water. After a couple of minutes boiling the thermostat have opened about 3 mm. Is that enough ?
Update
Took the Jimny for a spin without thermostat installed. Temperature reading was steady just 1 mm above minimum. So will get a new thermostat monday
Update
Last edit: 12 Jan 2013 15:32 by TomDK.
12 Jan 2013 19:35 - 12 Jan 2013 19:36 #57826
Replied by mlines on topic Re: Jimny running hot ?
My road going Jimny runs at "8 o'clock" whilst my off-road Jimny ran at "9 o'clock" if you can picture in your mind the clock references.
Last edit: 12 Jan 2013 19:36 by mlines.
Time to create page: 0.454 seconds
