Jimny running hot ?
  • TomDK
  • Visitor
  • Visitor
12 Jan 2013 20:22 #57830 by TomDK
Replied by TomDK on topic Re: Jimny running hot ?
Sorry I can't...
Here in Denmark we only have digital watches :laugh: :laugh: B)
  • JivingDaddy
  • Visitor
  • Visitor
26 Jan 2013 18:19 #59731 by JivingDaddy
Replied by JivingDaddy on topic Jimny running hot ?
The wife's is running at just over halfway as well. Thought it might be an issue, but it seems not. Phew :)
  • TomDK
  • Visitor
  • Visitor
01 Feb 2013 14:16 #60551 by TomDK
Replied by TomDK on topic Jimny running hot ?
Has anyone fitted a thermostat with lower opening temperature?
Was out driving today and thought the engine smelled rather hot, like a slipping fanbelt. Only this is not the case. The Valvecover also felt very warm.
01 Feb 2013 17:40 - 01 Feb 2013 17:43 #60585 by kirkynut
Replied by kirkynut on topic Jimny running hot ?
The standard thermostat setting is fine. If it's running hot fix the cause not the symptom.
Radiators get clogged easily on Jimny's as the fins are fine and close together.
My Jimny runs between 89-91c all year round on my scan gauge - which brings up back to the suggestion of having one to see the actual temperature made earlier in this thread. The car's guage doesn't move past the half way point no matter what the temperature. When I had a clogged radiator it went up to 104c - quite alot for a system that does not have much pressure by design.
You've been on here long enough to have read the posts about the viscous fan unit breaking down, thermostats not opening enough / sticking and radiators getting clogged etc.
Work through it systematically until you find the solution, but nonetheless for the money it costs a new radiator would be the first thing I would do as in any case it can do no harm and only good.
If you get a scan gauge you can see the results to the degree c instantly for any changes you make and see problems in the cooling system rearing their ugly head early - like I did.
Without looking up what engine you have Tom, changing the thermostat on a twin cam is a pain in the back side. So if there is nothing wrong with the one you haveand you have just got a clogged radiator, change the rad and put in a high concentration of coolant back in to prevent sludge build up and rust in the system and the thermostat should last ok.
If the fan belt was slipping I would have thought you'd have heard it, but again, for what it costs, change it and the power steering belt and leave the old ones in the boot as spares.
Last edit: 01 Feb 2013 17:43 by kirkynut. Reason: spelling
The following user(s) said Thank You: TomDK
  • TomDK
  • Visitor
  • Visitor
01 Feb 2013 19:06 #60597 by TomDK
kirkynut wrote: The standard thermostat setting is fine. If it's running hot fix the cause not the symptom.
My engine is a G13, so changing the Thermostat is no big deal. Which I've also tried, but with no change. My temperature gauge goes up to around 3/4, so the gauge covers the temp symbol.
I'm just beginning to wonder as I tried driving the Jimny with the thermostat removed, and then it took about 30 mins I'm wrong.
I don't think it's the fanbelt slipping, none of the belts appear warm, worn or anything.
So, for starters I will try removing the radiator and clear it inside and outside.
