Winch battery set up?
- BigMat
08 Jan 2013 18:04 #57539
by BigMat
Winch battery set up? was created by BigMat
Whats the best and cheapest way to run twin batteries for my winch? Or even single battery if someone knows different?
- Sponnie
08 Jan 2013 18:37 #57546
by Sponnie
Replied by Sponnie on topic Re: Winch battery set up?
Ive seen some guys use a larger battery in the place of the orginal with great results.
If your competeing then i expect twin batts are the way to go, with a dedicated winch batt and perhaps even a twin alternator set up for shorter duty cycles.
X eng do a good split charge set up thays well reccomended on here.
Im sure one of the 'pros' will be along with a boat load of links and advice for ya
Sent from my GT-I9300 using Tapatalk 2
- Blissett
08 Jan 2013 22:02 #57573
by Blissett
Replied by Blissett on topic Winch battery set up?
Split charge.... Problem with the x-eng one it needs a running feed. Jimny alternater light wire doesn't work. Voltage sensing is needed..I put a switch in to enable charging...
Move the water bottle forward and you can build a tray to put a 096 battery in... Had that laying about from the discovery I had.. That is what I have done..
Have fun
Mark
Have fun
Mark
- TomDK
08 Jan 2013 22:26 #57577
by TomDK
If used for challenge, forget split charge and get a pair of numax batteries. from what I can read on different forums, they're great for a budget winch truck
Replied by TomDK on topic Winch battery set up?
BigMat wrote: Whats the best and cheapest way to run twin batteries for my winch? Or even single battery if someone knows different?
- adamjimny
08 Jan 2013 22:59 #57586
by adamjimny
Replied by adamjimny on topic Winch battery set up?
I just got a numax 125ah battery given by work in good nick. Asking for the other 4 tomorrow.....never have too many ha
- Sponnie
09 Jan 2013 22:21 #57672
by Sponnie
