G13bb engine
- Cider
06 Jan 2013 13:01 #57260
by Cider
G13bb engine was created by Cider
Hi
Are there two types of g13bb jimny engine,one with a crank sensor and one without.
will they run on each others ecu
Thanks
Thanks
06 Jan 2013 13:19 #57263
by facade
Replied by facade on topic G13bb engine
Yes there are, and no they won't
There have been some posts on here about it, the cam shaft is different: it has a different number of sensor teeth, someone machined his camshaft to work, so I don't think that there is a pulley that you can change.
Try a bit of searching around the forum, or maybe the person who did the swap will reply.
The following user(s) said Thank You: Cider
06 Jan 2013 13:53 #57264
by j999pre
Grey pick up Jimny
Replied by j999pre on topic G13bb engine
I did a swap like this. It was putting a hard top into a soft top.
The hard top cam wheel on the back of the cam has different numbers of teeth.
So I compared them removed the spare teeth. The pulley was pressed off and orientated correctly. It ran spot on after.
Grey pick up Jimny
The following user(s) said Thank You: facade, Cider
06 Jan 2013 14:27 #57266
by j999pre
Grey pick up Jimny
To go hard to into soft top I also had to swap the bottom pulley behind the crank pulley, swap the sump and drill the oil pump to take the sensor. You good re use your cam as long as its ok and the journals are the same size.
Putting the soft top into hard top is easier as you only need to swap the cam.
Grey pick up Jimny
Time to create page: 0.238 seconds
