holts rad flush 2 part
  • suzuki jimny fella
02 Jan 2013 23:05 #56997 by suzuki jimny fella
Replied by suzuki jimny fella on topic holts rad flush 2 part
so fill the exspanion tank to full when cold is it thanks guys
02 Jan 2013 23:09 #56998 by suzuki jimny fella
have i done right with antifreeze guys had a 5l bottle of antifreeze and 5l bottle of distilled water,
so i put 2l of antifreeze in and 2.5 of distilled water there about's
03 Jan 2013 01:13 #57018 by facade
Replied by facade on topic holts rad flush 2 part
suzuki jimny fella wrote: so fill the exspanion tank to full when cold is it thanks guys
There is a level line about 1/2 way up marked COLD: fill only to the line or it may overflow.
The coolant capacity is supposed to be 4.5 litres, so 2 litres of antifreeze will give a 44% solution, should be fine.
03 Jan 2013 18:19 #57068 by suzuki jimny fella
This is what i used is this ok guys hope so
03 Jan 2013 22:30 #57108 by suzuki jimny fella
is this ok guys
03 Jan 2013 23:39 #57117 by facade
It will be fine with the distilled water.
Japanese cars as a rule don't originally fill with this type of antifreeze, but European cars do. Something to do with the hardness of the local water, but distilled water is as "soft" as you can get.
As far as I can google, the Japanese use the organic acid technology (OAT) antifreeze, which is pink in the UK.
All 3 japanese cars, and the 3 Japanese 'bikes I've had have been filled with green antifreeze though.
The antifreeze you have is fine for aluminium engines, don't worry about it.
Time to create page: 1.111 seconds
