holts rad flush 2 part
  • suzuki jimny fella
31 Dec 2012 22:13 #56747 by suzuki jimny fella
holts rad flush 2 part was created by suzuki jimny fella
as topic any one used this
01 Jan 2013 07:54 #56754 by facade
Replied by facade on topic holts rad flush 2 part
A few times, what is your question?
01 Jan 2013 20:55 #56829 by suzuki jimny fella
Replied by suzuki jimny fella on topic holts rad flush 2 part
Any good
02 Jan 2013 03:30 - 02 Jan 2013 03:32 #56868 by facade
Depends on what you mean by "good". It isn't a miracle cure for overheating.
It does remove some corrosion and scale, so if you have a slight overheating problem because of the insulating effect of corrosion/limescale it will help, it won't unblock blocked radiator tubes as the liquid can't get into the tube in the first place, but it will open up partially blocked ones.
If your radiator is old, removing the internal scale will cause it to leak, this can also be a problem with the heater matrix, marginal on a jimny at the best of times, so If you are using it, I'd disconnect the heater, and join the pipes together temporally.
Have to say that I've used it on cast iron engines that have not had corrosion inhibiting antifreeze, if the antifreeze is changed regularly there won't be much corrosion to shift.
The 2 parts are an acid to dissolve the corrosion, and an alkali to neutralise the acid (supposed to have some corrosion inhibitor in as well), as you can't get all the coolant out of a jimny this is important.
Last edit: 02 Jan 2013 03:32 by facade.
02 Jan 2013 14:16 #56898 by suzuki jimny fella
Well yesterday was a nice day no rain lol
well guy run the holts 2part solution through the system and then strip her down to change stat to find out that they supplyed the wrong one tamping so when in for a cupper tea and test the stat with the kettle and it opened so rebuilt it all back up and put new fluids in
drove 20min down road to work to day and the bottom hose was cold any ideas or do i need to go for a long spin
02 Jan 2013 14:17 #56899 by suzuki jimny fella
What do you mean about heater matrics buddy
Time to create page: 0.394 seconds
