Camac tyre pressures
  • garrygun
29 Dec 2012 17:32 #56513 by garrygun
Camac tyre pressures was created by garrygun
Hi guys, im running on Camac 4x4 think called terra 215/75-15...
what pressures would you recomend for road use also light off road,are these tyres normaly very noisy?
Cheers Garry.
29 Dec 2012 17:54 #56517 by kirkynut
Replied by kirkynut on topic Camac tyre pressures
I would go for standard tyre pressures whatever they are in the book - mines been modified too long for me to worry about what the book says!
Tyre noise can't be bad from those as they are barely an AT tyre. Again, it's a long time since I could notice not having a hum or whine from tyres or rocklobster so I don't know what they are like compared to road tyres.
  • garrygun
29 Dec 2012 18:52 #56524 by garrygun
Replied by garrygun on topic Camac tyre pressures
kirkynut wrote: I would go for standard tyre pressures whatever they are in the book - mines been modified too long for me to worry about what the book says!
I havnt a clue what the standard pressures are for these tyres but they sure are noisy, maybe running under inflated.
garry.
  • Dave n lincs
29 Dec 2012 18:59 #56525 by Dave n lincs
Replied by Dave n lincs on topic Camac tyre pressures
I have 215 75 15 mt tyres and I run them at the book pressures which is 23 psi front and 26 psi rear. I find it drives good on and off road at that. When I bought my j it drove like a brick with 30 psi all round. Not advised if you want to keep your fillings. Lol
  • garrygun
29 Dec 2012 19:25 #56529 by garrygun
Thanks for that, i do think the rears are over inflated and fronts are way too low,
first thing tomorow i will check and inflate as you say hopefully it will feel a bit better drive.
Cheers Garry.
  • Barnyzuki
29 Dec 2012 21:39 - 29 Dec 2012 21:41 #56555 by Barnyzuki
Replied by Barnyzuki on topic Camac tyre pressures
I have been running Camac Terra A/Ts in 215R15 on my Jimny and they are silent.
23 psi all round I think.
Last edit: 29 Dec 2012 21:41 by Barnyzuki. Reason: wrong tyre pressure typed.
