Swivel Joint ball
- jimnyonhigh
- Visitor
29 Dec 2012 14:29 #56487
by jimnyonhigh
Replied by jimnyonhigh on topic Swivel Joint ball
Indeed a new seal was fitted before the shaft was fitted because it looked very degraded
29 Dec 2012 15:02 #56489
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Swivel Joint ball
Was that the outer seal our the small inner one?
Grey pick up Jimny
- jimnyonhigh
- Visitor
29 Dec 2012 15:09 #56491
by jimnyonhigh
29 Dec 2012 15:42 #56493
by facade
Replied by facade on topic Swivel Joint ball
Most likely there is too much grease in the swivel housing.
Eventually the surplus will stop coming out.
The following user(s) said Thank You: jimnyonhigh
- jimnyonhigh
- Visitor
29 Dec 2012 17:02 #56506
by jimnyonhigh
Facade thats exactly what i thought, i wanted to get some information and advice from the more experienced before i took action and started tinckering.
29 Dec 2012 17:24 #56511
by kirkynut
You could undo the ring of 10mm headed bolts that hold these swivel seals on to have a look in them for yourself to see how much grease is in there and wipe any excess out. Don't wipe your kingpin bearings dry though, just any excess around the housing.
If you smell cats piss and the grease appears watery then the axle oil seal for the shaft has failed and diff oil is leaking, but you've had a new one of them so it should be ok. I'm not convinced you needed a new shaft though.
Perhaps have a go yourself in the future. We'll support and advise you and you have how to sections to help too.
Replied by kirkynut on topic Swivel Joint ball
jimnyonhigh wrote: This is what was fitted with the halfshaft and of course the small axel oil seal that came with my kingpins, the kingpins did not need fitting though.
Time to create page: 0.189 seconds
