timing chain !
- jfkenpoman
28 Dec 2012 10:29 #56399
by jfkenpoman
timing chain ! was created by jfkenpoman
another question for you knowledgeable guys and girls, does the jimny with M13AA engine (double overhead cam) run a timing belt or cam chain? what are the replacement times/mileage, if it is a belt?
28 Dec 2012 10:56 #56400
by facade
Replied by facade on topic timing chain !
Chain
Lasts the life of the engine (because when it breaks it kills the engine
Just keep changing the oil and filter and it will last a couple of hundred thousand miles.
- barnes
28 Dec 2012 13:08 #56407
by barnes
Replied by barnes on topic timing chain !
What about the earlier single cam 16valve whats the recommended belt change?
- dirtydogz
28 Dec 2012 14:31 - 28 Dec 2012 14:32 #56415
by dirtydogz
Replied by dirtydogz on topic timing chain !
Suzuki manual said 60.000, I replaced my cambelt at 32.000 when I got the jimny, if you do replace the cambelt get a replacement kit and a new water pump at the same time.
Last edit: 28 Dec 2012 14:32 by dirtydogz.
- jfkenpoman
28 Dec 2012 23:06 #56463
by jfkenpoman
Replied by jfkenpoman on topic timing chain !
thanks for the info guys
