help front drives coil hits chassis
  • adamjimny
  • Visitor
  • Visitor
26 Dec 2012 23:26 #56306 by adamjimny
Replied by adamjimny on topic Re: help front drives coil hits chassis
You got normal bushes in them now then? As above are you sure they are rear arms? And as above again with CC mine werent even close to that bend and are perfectly straight with CC arms.....id check every inch of the new bits thats been put on ie springs panards CC arms etc and make sure its all on correctly etc
Are the CC arms on the right way up etc. Failing that take lots of pics and post on here and we will see if we can spot anything wrong etc
sent from my Samsung Galaxy S2 using tapatalk
  • suzuki jimny fella
  • Visitor
  • Visitor
27 Dec 2012 12:51 #56331 by suzuki jimny fella
Replied by suzuki jimny fella on topic help front drives coil hits chassis
Ok thanks Will do that yer arms are front ones of rus and ploybushes in them new Packard arm bushes and new coils on but can not work out why there is that much bow in them doing my head in fair play lol
27 Dec 2012 16:46 - 27 Dec 2012 17:00 #56344 by dirtydogz
Just been look at your photos, is your jimny on a level surfaces as the bush in the photo look twisted, you might have damaged the driver's side arm.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 27 Dec 2012 17:00 by dirtydogz.
  • Visitor
  • Visitor
27 Dec 2012 20:06 #56365 by suzuki jimny fella
no it on about full flex in pic mate that when it hits it :-( will get pic of it on the flat for you in morning
  • Visitor
  • Visitor
29 Dec 2012 16:40 #56505 by suzuki jimny fella
Had the Jimny in my mates garage to day we put a tracker 400 on to see if it was tracked up ok and it was spot on so i am still stuck here
  • Visitor
  • Visitor
29 Dec 2012 21:18 #56553 by suzuki jimny fella
hi rus can you help me as your the man the lift kit and front arms are of its is bugging me lol lol hope you can help bro as you have been brill in the past thanks fella
Time to create page: 0.153 seconds
