help front drives coil hits chassis
- suzuki jimny fella
- Visitor
26 Dec 2012 15:26 #56257
by suzuki jimny fella
help front drives coil hits chassis was created by suzuki jimny fella
As topic when on twist it prangs when hits chassis Will put photos up when on lap top has anyone had this problem on there jimmy i have caster corrected arms for the lift and coil do bow
- adamjimny
- Visitor
26 Dec 2012 18:18 #56272
by adamjimny
Replied by adamjimny on topic help front drives coil hits chassis
is the axl centered? is there play in bushings? spring looks very curved when it should be straight
- Visitor
26 Dec 2012 18:56 #56274
Replied by suzuki jimny fella on topic help front drives coil hits chassis
the only thing left to do is 4wheel align it but dont think that will fix it
its bow like mad dont it
- adamjimny
- Visitor
26 Dec 2012 19:44 #56276
by adamjimny
the springs should not bow like that after caster correction. mine are straight. it looks very very bad. should be straight
have you extended the panard rod to re-centre the axle under the car because i have and mine doesnt touch at all
26 Dec 2012 19:59 #56278
by kirkynut
Replied by kirkynut on topic help front drives coil hits chassis
I'm not sure it's possible to put the rear arms on the front but are you sure you have front arms on the front?
Castor correction arms are meant to eliminate that bowing. Even before I had my castor correction arms with 3" spring mine never bowed like that.
- Visitor
26 Dec 2012 20:07 #56280
yer got jimny bits cc arms on front and adjustable panhard arms mad in it
Time to create page: 0.252 seconds
