Check engine/immoboliser warning
  • pixywixy
23 Dec 2012 19:42 #56065 by pixywixy
Check engine/immoboliser warning was created by pixywixy
hello all
i have a 2002 jimny, today whilst driving back on the A30 the check engine and immoboliser warning light started flashing and the tachometer needle was moving up an down chaotically. i had to pull over as the engine was chugging, managed to get home but kept the speed to 50mph. do any of you guys have an idea as to what caused this? thanks for any replies
23 Dec 2012 20:05 #56067 by facade
Crankshaft sensor most likely.
Found on side of engine block between alternator and block.
The following user(s) said Thank You: pixywixy
  • adamjimny
24 Dec 2012 12:28 #56100 by adamjimny
Replied by adamjimny on topic Check engine/immoboliser warning
as above usually find them called a 'cam angle sensor'
  • vitara_mad
24 Dec 2012 12:36 #56101 by vitara_mad
Replied by vitara_mad on topic Check engine/immoboliser warning
use this to find the problem
www.rhinopower.org/diag/cel.html
24 Dec 2012 19:32 #56134 by j999pre
Covered in loads of threads.
Use the search and your answers will be forth coming.
Grey pick up Jimny
