Driveline maintenance
- mik641
20 Dec 2012 05:38 #55825
by mik641
Driveline maintenance was created by mik641
Hi guys,
have picked myself up a jimny which has done 60,000km . Just wondering whether the hubs axles or driveshafts etc need greasing and where and how i do it.
Am looking to do the transfer and diff oils at the same time.
Cheers!
Cheers!
- ZookFastback
20 Dec 2012 07:11 - 20 Dec 2012 07:14 #55827
by ZookFastback
Replied by ZookFastback on topic Driveline maintenance
The Uni's as supplied don't need greasing but they may have been changed (like mine) for greasable ones so you will have to pop under and check. My originals seized up so that is why I changed them to greasables and I grease after any water event. They seem to be lasting forever.
When you change the diff oils check to see if any water has entered. The oil uwill have gone milky if water has mixed. Most of us fit tubing to the diff breathers by knocking the caps off and run the tubing up high into the engine bay so that no water enters the diffs.
Last edit: 20 Dec 2012 07:14 by ZookFastback. Reason: Left last paragraph off
23 Dec 2012 10:52 #56041
by kirkynut
Replied by kirkynut on topic Driveline maintenance
There is a grease nipple on the props which greases the sliders of the props.
Then it is just changing all the transmission fluids as said above. Note the gearbox uses different fluid to the diffs and transfer box.
- mik641
26 Dec 2012 03:02 #56226
by mik641
Replied by mik641 on topic Driveline maintenance
Yep have changed the diff and transfer oils so far.
I cant see any grease nipples on the drive shafts but there is a rubber boot joining one of them with plenty of grease inside.
Wha about the hubs, like the cv or nuckle joints ?
26 Dec 2012 10:50 #56243
by facade
Order a kit to do the swivel (kingpin) bearings. (try the shop here)
Repack the CVs with grease at the same time.
(The swivel bearings always need changing, every couple of months, but most of us put them off for a couple of years between sets.
Replied by facade on topic Driveline maintenance
mik641 wrote:
What about the hubs, like the cv or knuckle joints ?
- mik641
27 Dec 2012 07:49 #56317
by mik641
Is this a common problem that the kingpin bearings wear quickly or is it only under alot of offroad use?
