jimny chip or to chip
11 Jan 2014 13:32 - 11 Jan 2014 13:39 #100100 by Rhinoman
Replied by Rhinoman on topic jimny chip or to chip
gaffertoo wrote: The did say them most important thing is to make sure that the sensor in the box or sometimes in the rubber part of the manifold is very clean as this can cause it to run rich or misfire or even run erratically.You must how ever use the right cleaner for the job,not break cleaner .So there you have it,every time you change the air filter clean the sensor as well and it says also about rebooting after you clean it but you will have to look your self on that one
They are referring to a MAF, which the Jimny doesn't have - its a MAP based system.
The resistor usually fits in series with the Intake Air Temperature Sensor and as stated previously makes the sensor report that the air is a little cooler which richens up the fuel. Where this tends to go awry is that the ECU uses the feedback from O2 sensor to correct the mixture so it should pull the fuelling back. If the required correction is outside the range of the ECU then the ECU will go into a fail safe mode - on an OBD1 ECU this will not set the Check Engine Light but will cause the ECU to overfuel.
You can usually get about a 5% gain from tuning an ECU on a stock engine but most of the improvements come from changes to the timing map.
Last edit: 11 Jan 2014 13:39 by Rhinoman.
Time to create page: 0.138 seconds
