Grrr Problems Refitting Gearbox
- Smoggy
17 Dec 2012 19:46 #55682
by Smoggy
Grrr Problems Refitting Gearbox was created by Smoggy
In the process of changing my clutch all has gone reasonably to plan until now
I have followed Martin's comprehensive guide to the letter. I have fitted the clutch friction and pressure plate and used a clutch alignment tool to centralise it. When I get the gearbox close with the bottom nearside threaded stud in the locating hole on the engine block it will not go any further despite any amount of 'jiggling'. The cause is not the 2 blank metal locating pins as they are still a couple of mm from their engine block locating holes. I have even tried jacking the engine forward slightly and jacked up/down the rear edge of the box to change the 'attack' angle.
I realise I am no mechanic and if it wasn't for the fact that I really want to learn how to do this for the future I would be beginning to wish I had paid the garage to fit it
17 Dec 2012 20:16 #55686
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Grrr Problems Refitting Gearbox
You could try a socket on the crankshaft pulley to turn the engine slight as you shove it. Worked for me once.
Grey pick up Jimny
- adamjimny
17 Dec 2012 20:29 #55689
by adamjimny
this worked for me too. i had exactly same problem.....struggled for 2.5 hours just trying to get it back on untill i did this and on it went
Replied by adamjimny on topic Grrr Problems Refitting Gearbox
j999pre wrote: You could try a socket on the crankshaft pulley to turn the engine slight as you shove it. Worked for me once.
- Smoggy
17 Dec 2012 20:46 #55691
by Smoggy
Replied by Smoggy on topic Grrr Problems Refitting Gearbox
Thanks guys. I have been buggering about for even longer than that Adam
- adamjimny
17 Dec 2012 20:54 #55693
by adamjimny
i know the feeling i was getting ready with the sledge hammer :laugh:
Smoggy wrote: Thanks guys. I have been buggering about for even longer than that Adam
- dirtydogz
17 Dec 2012 21:03 #55694
by dirtydogz
Replied by dirtydogz on topic Grrr Problems Refitting Gearbox
Did you try the clutch plate on the main shaft to see if it fits first :dry: , I had to return two clutch units back to allparts till I got the right one.
Time to create page: 0.196 seconds
