TG crawler box
  • jimnydms
15 Dec 2012 12:30 #55567 by jimnydms
TG crawler box was created by jimnydms
Hi has anyone fitted a TG crawler box (sj case) to a jimny ?
If so did you have problems with the positioning of the selector stick catchin on the body ? Did you have to bend the stick or use another method ? Also did you use a breather if so what kind of set up as jubileeing a pipe over the nipple catches on the underside of the body, cheers
  • TomDK
15 Dec 2012 12:33 #55568 by TomDK
Replied by TomDK on topic TG crawler box
jimnydms wrote: Hi has anyone fitted a TG crawler box (sj case) to a jimny ?
It's the same as fitting a rocklobster in the Jimny. it's just the gearing that's lower. So yes, gear stick needs bending.
Search forum for rocklobster.
  • jimnydms
15 Dec 2012 19:49 #55585 by jimnydms
Replied by jimnydms on topic TG crawler box
Can't find anything grrr only searching from tapatalk though do you have any links ?
  • TomDK
15 Dec 2012 20:03 #55586 by TomDK
Time to create page: 0.173 seconds
