Engine Coolant/thermostat
  • suzuki jimny fella
09 Dec 2012 19:58 #55226 by suzuki jimny fella
Engine Coolant/thermostat was created by suzuki jimny fella
hi all had my temp go up to day twice doing strata struggled to start then put it though river and it then cleared for the 80 mile trip home is it i have a sticky thermostat and what coolant do jimny take
what one do i need will go halfords for it
thanks
  • supergaz
09 Dec 2012 20:13 #55229 by supergaz
Replied by supergaz on topic Engine Coolant/thermostat
Check your radiator is clean of mud, check carefully around the back of it inside the shroud to ensure there is no trapped mud.
09 Dec 2012 20:31 #55233 by suzuki jimny fella
Replied by suzuki jimny fella on topic Engine Coolant/thermostat
will do fella think it is clean but will check what coolant goes in it where is the thermostat to
thanks
10 Dec 2012 13:59 #55255 by suzuki jimny fella
Where is the thermostat located on the engine guys
  • Keefe
10 Dec 2012 15:11 #55258 by Keefe
Replied by Keefe on topic Engine Coolant/thermostat
Under the inlet manifold towards front of engine.
Unless it's the G13 motor?
  • reaper
10 Dec 2012 15:58 #55262 by reaper
Replied by reaper on topic Engine Coolant/thermostat
On the a engines follow the short top dad hose the themostat is in that cast bit bolted to engine with 2 bolts
Time to create page: 0.174 seconds
