Brake Master and Brake issues!
  • J-Bro
09 Dec 2012 07:58 #55176 by J-Bro
Brake Master and Brake issues! was created by J-Bro
Okay the other day my brakes went rubbish!
The pedal would go to the floor or I'd have to pump the pedal for it to work.
So as I checked for leaks and there were none.
So off to the garage.
They said break master cylinder. So they gave me a price of £240 for the part.
So I bought one for £50 used off eBay. It also came with the servo.
Garage fitted master only.
Breaks working fine until my foot went to the floor again and no breaks. When driving forwards it now seems to be fine allthough it does get soft sometimes. I'm not a heavy breaker or anything.
But the weird thing is the brakes basically don't work in reverse!
Can anyone help?! As brakes are kinda needed! Ha
  • ne-crock
09 Dec 2012 08:35 #55177 by ne-crock
Replied by ne-crock on topic Brake Master and Brake issues!
This happened to me recently after fitting a new axle and turns out i hadnt bled the brakes properly anyway i let my local mechanic sort it, he said to get a real good bleed he had to bleed it 6-7 to get all the air out of the system,
Its a bit unearving going at 70 trying to slow down and realising you have no brakes
  • J-Bro
09 Dec 2012 11:36 #55183 by J-Bro
Replied by J-Bro on topic Brake Master and Brake issues!
Or reverse up onto your parents drive way and hit the garage door?
Ill give it ago!
What about the servo? I have a new one if needs be
  • GuardianAngel
10 Dec 2012 13:32 #55253 by GuardianAngel
  • J-Bro
11 Dec 2012 06:54 #55322 by J-Bro
Ah
In garage this weds will mention that!
  • GuardianAngel
15 Dec 2012 17:55 #55581 by GuardianAngel
Replied by GuardianAngel on topic Re: Brake Master and Brake issues!
J-Bro wrote: Ah
How did you get on and what was the fix?
Sent from my GT-I9100 using Tapatalk 2
