What's involved in?
  • Rob2933
03 Dec 2012 07:08 #54719 by Rob2933
What's involved in? was created by Rob2933
Hi guys me again can sombody tell me what's involved in changeling front hubs looking into it myself it looks quite easy just a point of taking the old vac ones of and replacing with the manule ones is that it!! I no I've got to disconnect the vac pipe from the engine any help will be good bob
03 Dec 2012 07:47 #54720 by mlines
Replied by mlines on topic What's involved in?
Thats about it, just unbolt the old ones and bolt on the new ones. If you don't mind the 4WD light flashing when in 4WD then you can leave the pipes in place.
Depending on what manual hubs you get you will need some bolt on spacers....
www.bigjimny.com/store/index.php/off-roa...b-adaptors/p_15.html
  • Rob2933
03 Dec 2012 07:49 #54721 by Rob2933
Replied by Rob2933 on topic What's involved in?
Cheers Martin that great I can now get on with it
Bob
  • Skinhead
03 Dec 2012 13:37 #54731 by Skinhead
Replied by Skinhead on topic What's involved in?
I dont know if you can see what ive done from this pic? If not just say and ill draw you a diagram, it took about 15 seconds to do.
  • Skinhead
03 Dec 2012 14:08 #54739 by Skinhead
Heres a diagram of the pic above, the thick bits are rubber pipe, the thin is solid pipe. I dont know what the rubber pipe is that Ts off but i drew it on, just ignore it. The rubber pipes just pull off and push on, easy.
  • Rob2933
03 Dec 2012 15:14 #54746 by Rob2933
Hi mate got it that's for your time I'm just waiting for me new hubs to come so now I've got all the info needed to get on it will post when done thanks guys bob
