sj solid hubs
  • Bish
27 Nov 2012 11:09 #54287 by Bish
sj solid hubs was created by Bish
Has anyone fitted sj solid hubs to a jimny?
I'm doing away with the auto hubs and don't have much need for manual hubs.
  • Paul4x4
27 Nov 2012 13:38 #54290 by Paul4x4
Replied by Paul4x4 on topic sj solid hubs
If there's SJ locking hubs fitted on Jimny's with a spacer ring, surely those solid ones will fit too the same way. :)
  • Bish
27 Nov 2012 14:01 #54293 by Bish
Replied by Bish on topic sj solid hubs
Thats what I'm assuming but you know what they say about assumption!!
Would I even need the spacers? I'm not sure tbh.
  • goatboy
27 Nov 2012 16:22 #54297 by goatboy
Replied by goatboy on topic sj solid hubs
Why not take the auto hubs off, engage them by hand and stick a blob of weld in there so they don't move.
Free locked hubs and no need for spacers?
  • Bish
27 Nov 2012 16:37 #54298 by Bish
only problem with that is when I need to change a diff or shafts etc.
I'd rather have free wheeling hubs than weld.
  • goatboy
27 Nov 2012 17:00 - 27 Nov 2012 17:02 #54299 by goatboy
no, you misunderstood.
The vacuum hubs have 2 rings that slide in and out of each other to engage/disengage.
Just put them in the engaged position (which you can do with your hand) and then weld the rings to each other within the vacuum hubs. Then just bolt it back on. No need to touch shafts or diffs...
It would achieve the same thing as SJ solid hubs but you won't need to source hubs or spacers.
Last edit: 27 Nov 2012 17:02 by goatboy.
