Water Ingress
  • Smoggy
23 Nov 2012 21:15 #54063 by Smoggy
Water Ingress was created by Smoggy
Of you guys that have had your Jimnys through deep water, where if anywhere have you noticed the water creeping into your cabs?
I would expect the usual spots being door seals, rear arches where the clips punch through from arch trims, handbrake cable grommet, gearshift gaiter(s), holes in the rear floor :laugh: etc.
  • p1ngu32
23 Nov 2012 21:58 #54066 by p1ngu32
Replied by p1ngu32 on topic Water Ingress
Ive been up to the door handles in water and never had any come in. It floats on top of the water rather than letting it in :)
  • reaper
23 Nov 2012 22:03 #54067 by reaper
Replied by reaper on topic Water Ingress
Small seaps here and there but worst one was the air valve near the rear door , still not figured a way to stop water but keep the function
23 Nov 2012 22:41 - 23 Nov 2012 22:42 #54074 by j999pre
Replied by j999pre on topic Water Ingress
reaper wrote: Small seaps here and there but worst one was the air valve near the rear door , still not figured a way to stop water but keep the function
Maybe replace it with some form of clack valve? Air pressure from shutting doors would open it but water pressure from outside would close it? Or a simple spring loaded version that opens due to air pressure but otherwise it's shut?
Grey pick up Jimny
Last edit: 23 Nov 2012 22:42 by j999pre.
  • reaper
23 Nov 2012 22:44 #54075 by reaper
That was the only thing i could see working , spring loaded plate with some high density foam for a seal
  • Smoggy
23 Nov 2012 22:54 #54077 by Smoggy
Replied by Smoggy on topic Water Ingress
Mmm thats interesting I forgot about those, there are 2 I think one each side of the tailgate. Whats your handbrake cable seal like mines a big oval hole with no grommet.
