Insa Turbo Special Tracks
  • supergaz
23 Nov 2012 10:40 #54011 by supergaz
Replied by supergaz on topic Insa Turbo Special Tracks
I am a specialist brake tester engineer and there is no reason that special tracs cannot be used. I also have special tracs on my jimny.
  • Beano
23 Nov 2012 12:03 #54016 by Beano
Replied by Beano on topic Insa Turbo Special Tracks
Put a strip of electrical tape over the 'off road use'...
Legally, MOT testers cannot remove anything from the vehicle so if he cant see it, he cant fail it.
Trust me, has worked for over 10 years of getting illegal motorcycle exhausts thru MOTs! :whistle:
  • supergaz
23 Nov 2012 16:41 #54031 by supergaz
Insa turbo special tracs are perfectly road legal so no need to cover anything up.
  • markyp2000
23 Nov 2012 17:49 #54035 by markyp2000
Replied by markyp2000 on topic Insa Turbo Special Tracks
Beano wrote: Put a strip of electrical tape over the 'off road use'...
your wrong we can remove thing from the car on test ie fuel cap, any thing stuck to the screen/mirror causing an odstruction any trim panel the only thing you cant do is use tools to remove any thing ie engine covers/trims
as for the tape on the tyre id remove it due to it may be hiding damage to the side wall
  • vitara_mad
23 Nov 2012 19:37 #54053 by vitara_mad
Replied by vitara_mad on topic Insa Turbo Special Tracks
im with gaz they are perfectly road legal so theres no reason for them to fail mot
i would go to a differant mot center & report the one you are using now
  • markyp2000
23 Nov 2012 20:28 #54057 by markyp2000
Smoggy wrote: Has anyone had any issues with these tyres failing MOT as my Jim has just failed on illegal tyres, the tester said the sidewall states 'off road use only' (infact it just states off road), he said he couldnt do the brake function test since the aggressive tread pattern tricks the test machine into thinking the brakes are juddering.
Any comments much appreciated.
could you post a pic of it on the tyre
Time to create page: 0.239 seconds
