Insa Turbo Special Tracks
- Smoggy
22 Nov 2012 21:24 #53948
by Smoggy
Insa Turbo Special Tracks was created by Smoggy
Has anyone had any issues with these tyres failing MOT as my Jim has just failed on illegal tyres, the tester said the sidewall states 'off road use only' (infact it just states off road), he said he couldnt do the brake function test since the aggressive tread pattern tricks the test machine into thinking the brakes are juddering.
Any comments much appreciated.
- markyp2000
22 Nov 2012 21:29 #53950
by markyp2000
Replied by markyp2000 on topic Insa Turbo Special Tracks
put your standard wheel on just for the mot
and sand off the off road on the tyres then if you get stoped by the police thay wont see it and he is right about failing it on the info on the tyre and the brake tester my pick it up as in balance not brake judder as the rolers dont roll that fast
- darthloachie
22 Nov 2012 21:33 #53952
by darthloachie
Replied by darthloachie on topic Insa Turbo Special Tracks
we've got the same tyres and it has passed both years with no problems
the guy that does the mot also does some work on it and also MOTs and services all our other family cars
- Smoggy
22 Nov 2012 21:35 #53953
by Smoggy
Replied by Smoggy on topic Insa Turbo Special Tracks
Cheers Marky, thought you might know.
- ooky_123
23 Nov 2012 01:04 #53986
by ooky_123
Replied by ooky_123 on topic Insa Turbo Special Tracks
had the sam eissue with the Diamond backs on ooky, they were marked Race Use only too.
wheel swap for MOT usually did the trick, however I know the Some of the other Simex copies are legal for road use
- Blissett
23 Nov 2012 07:04 #53996
by Blissett
Replied by Blissett on topic Insa Turbo Special Tracks
My special tracks went through no problem..... Try another mot station?????
Time to create page: 0.169 seconds
