Annoying noise....stumped!!!
  • Jimnyadmirer
  • Visitor
  • Visitor
23 Nov 2012 08:22 #53999 by Jimnyadmirer
Replied by Jimnyadmirer on topic Annoying noise....stumped!!!
I'm not 100% sure zookfastback, I'm new to the world of jimnys and a very amateur mechanic... Electrician to trade so I'd be alright if I had a problem with the electrics!!! Ha.
  • Jimnyadmirer
  • Visitor
  • Visitor
23 Nov 2012 08:33 #54001 by Jimnyadmirer
Found this but doesn't seen to be rubbing, cleaned everything out... :blink:
Can you buy replacement back plates or should I weld a patch or two?
23 Nov 2012 14:12 #54026 by j999pre
Sent you a pm. If you did replace the backplate you would have to do the rear wheel bearings too.
Grey pick up Jimny
  • Rob2933
  • Visitor
  • Visitor
23 Nov 2012 18:36 #54045 by Rob2933
Replied by Rob2933 on topic Annoying noise....stumped!!!
Does it do it in four wheel drive ? I had the same it was the front vac hub leaking putting it in four wheel stop it then back into normal drive it would be ok for a while then start again
  • Jimnyadmirer
  • Visitor
  • Visitor
23 Nov 2012 19:02 #54047 by Jimnyadmirer
J999pre, sent you a PM back.
I had it in 4 wheel drive for awhile today and didn't get up any great speed to try it out to Be honest! Haven't had much of a chance to look into it again today at all.
I did notice however that even at a speed lower than 30mph web I hit a bump in the road it would rear its head for a short while!?
Think it's time to take the wheels off again...
Bought myself a pair of axle stands today... Need to beat this niggle!!!
  • Jimnyadmirer
  • Visitor
  • Visitor
24 Nov 2012 13:22 #54092 by Jimnyadmirer
Right, got the car up on the jack and stands this morning and have found a little something which may point towards the noise??
Found this... Think the seal has gone and it could be running dry of grease? Dirt trapped inside?
Just working out on the street today and its freezing, so might have to wait till next week once I clear some of the rubbish out of my garage!!
