Annoying noise....stumped!!!
- Jimnyadmirer
- Visitor
22 Nov 2012 13:09 #53907
by Jimnyadmirer
Annoying noise....stumped!!! was created by Jimnyadmirer
Hi all,
Well, less than a week into owning my used Jimny, I'm getting this really annoying noise...
It sounds a bit like a metal on metal / grinding / whirring / rotating noise coming from the under side of the car..
It starts at around 30mph (ish) and continues all theway up and down the speedo until I'm almost stopped... Around 10-15mph. It's even still there when clutch is disengaged and its outif gear...
So far ice had all the wheels off.... Scraped all the rust of the backplates and disc edges.... Had the rear drums off and cleaned out all the rust in there too (did find the drivers side rear drum back plate rusted through and thought that might be the cause..... But noise is still there!)
Could it be anything to do with prop shafts etc?
Have had a look on the forums relating to this but so far could only find info on the disc backplates.... Has anyone encountered this problem and rectified it??
Your help is greatly appreciated!!
Thanks
Ian.
Thanks
Ian.
- markyp2000
- Visitor
22 Nov 2012 18:14 - 22 Nov 2012 18:16 #53925
by markyp2000
Replied by markyp2000 on topic Annoying noise....stumped!!!
try looking at the heat sheld on the exhaust near the cat
make shore your in 2wd
Last edit: 22 Nov 2012 18:16 by markyp2000.
- Jimnyadmirer
- Visitor
22 Nov 2012 19:30 #53931
by Jimnyadmirer
Replied by Jimnyadmirer on topic Annoying noise....stumped!!!
Hi markyp,
I've checked the heat shield to see if its loose and it seems pretty solid!!
I'm just beginning to wonder if its a dry bearing or a bearing on the way out?
It's really hard to pinpoint the source!! Driving me round the bend!!
- ZookFastback
- Visitor
22 Nov 2012 20:32 #53936
by ZookFastback
Replied by ZookFastback on topic Annoying noise....stumped!!!
Are your uni joints greasable? Or have you tried spraying into the CV joint on tailshaft?
22 Nov 2012 20:38 #53939
by facade
Replied by facade on topic Annoying noise....stumped!!!
You could take a risk and jack up both rear wheels, putting the axle on secure axle stands, then drive the car to 40 mph and see if it still makes the noise, then you will know it is in the driveline or rear axle.
(Be careful that it doesn't come off the stands, or a wheel touch the floor, be ready to brake quickly)
Then you could take the bigger risk of getting someone else to "drive" whilst you go around listening for the noise.
(I wouldn't advise getting underneath though)
- Jimnyadmirer
- Visitor
23 Nov 2012 08:20 #53998
by Jimnyadmirer
I'm thinking that might have to be the way forward at the moment... Can't see any other way round it... Dot really want to take it to a garage yet, especially at this time of year etc... Could end up costing a fortune!!
Time to create page: 0.189 seconds
