Half shaft
- jimnyonhigh
21 Nov 2012 18:48 - 21 Nov 2012 19:48 #53835
by jimnyonhigh
Half shaft was created by jimnyonhigh
Hi all
Just a newbie question
i need a new half shaft for the front left passenger side.
Is the half shaft shorter on the left than on the front right drivers side ?
I understand the CVS are the same.
Also i need to get hold of the hidden clip that holds in the half shaft and CV, anybody have a part number and a website which sells them.
Thank you
Thank you
Last edit: 21 Nov 2012 19:48 by jimnyonhigh. Reason: mistakes
- markyp2000
21 Nov 2012 20:11 #53846
by markyp2000
Replied by markyp2000 on topic Half shaft
thay are different lengths drivers side is the short one and the cvs are the same
as for the hidden clip as far as i no on jimnys it just knocks off but if im wrong some one will correct me in shore
- jimnyonhigh
21 Nov 2012 20:15 - 21 Nov 2012 20:20 #53847
by jimnyonhigh
Replied by jimnyonhigh on topic Half shaft
Cheers Marky! Regarding the clips, do you need to put a new one in each time you change the Half shaft/CV ? I am not sure if these break when you take the clip away or if its recommended to put a new clip in place.
I would only assume you don't because there is not any on the site for sale.
If one is needed please could somebody point me in the right direction or is it something most mechanics would have in the workshop ?
Last edit: 21 Nov 2012 20:20 by jimnyonhigh. Reason: mistakes
- vitara_mad
21 Nov 2012 22:08 #53866
by vitara_mad
Replied by vitara_mad on topic Half shaft
no you don't need a new clip when fitting new cv to a shaft
- markyp2000
21 Nov 2012 22:11 #53868
by markyp2000
but make shore the clip is even all the way round as you fit it cos some times thay dont go as thay should and twist
Time to create page: 0.223 seconds
