Are locking/unlocking front hubs really needed?
- Jimny J
20 Nov 2012 20:27 #53786
by Jimny J
Are locking/unlocking front hubs really needed? was created by Jimny J
Hi all, Im a new member around here, but been a 4x4 mechanic and driver for a fair few years. Recently iv'e been having a little trouble with my vacuum opp hubs. And Im just curious of weather they are really necessary? Obviously there is the extra rotating mass, though due to the fairly low gearing I cant see that its really going to cause much of a noticeable difference. But is there really going to be that much extra ware on the diff and transfer gubbins?
Does anybody here run fixed front hubs permanently?
Also on a slightly related note, whilst ferreting around my local scrap yard I spotted an old shape Vitara with a decent set of manual locking hubs fitted. Would they be the same fitting as SJ or Jimny parts?
- jayjay1990
20 Nov 2012 20:52 #53791
by jayjay1990
Replied by jayjay1990 on topic Are locking/unlocking front hubs really needed?
my mate runs permanently locked hubs with no issues
and the vitara hubs should fit fine with a spacer ring on each
- vitara_mad
21 Nov 2012 11:42 #53820
by vitara_mad
Replied by vitara_mad on topic Are locking/unlocking front hubs really needed?
as jay said vitara hubs fit with 5mm spacer as do sj fwh's just if you do get them off a vitara don't get the plastic type they are crap
my bro was running his jimny with the vacume hubs perm locked for 2 years with no probs
- iloveics
21 Nov 2012 20:34 #53849
by iloveics
Replied by iloveics on topic Are locking/unlocking front hubs really needed?
do you realise that driving a jimny around in 4wd permanently is equivilent to driving a land rover around with diff lock engaged?
- reaper
21 Nov 2012 20:37 #53851
by reaper
Replied by reaper on topic Are locking/unlocking front hubs really needed?
Its not in 4wd unless you select it on the t-box mate
The hubs can be locked but still get no drive
21 Nov 2012 20:54 #53853
by facade
Replied by facade on topic Are locking/unlocking front hubs really needed?
Running the axle all the time will cause something to wear out eventually, unlike a LandRover there are no roller bearings supporting the halfshaft or CV.
However, with the mileage that most of us do on the road, I doubt if this will be a problem.
Time to create page: 0.156 seconds
