Bend, Cut or Weld ?
- ooky_123
21 Sep 2010 13:29 #4771
by ooky_123
Replied by ooky_123 on topic Re:Bend, Cut or Weld ?
Martin, i would rather not travel 3 hours each way to be honest
if you can put me in touch your "sympathetic" mechanic, that would be brilliant.
Qn, is it done on the car or does it need to be removed ?
21 Sep 2010 13:38 #4773
by kirkynut
Replied by kirkynut on topic Re:Bend, Cut or Weld ?
It will need to be removed Jason but am I right in thinking you have a standard transfer box rather than a Rocklobster?
I tried to get the lever out of my old transfer box after the Rocklobster was fitted and couldn't.
It has a plate with three bolts holding it down and then when they were undone I expected it to pull out but it didn't. I stopped bothering then as I did not want to break anything in case I ever wanted to sell it on or replace it.
The manual might tell you how to get it out or Martin might know where I was going wrong - I might have worked it out if I had persisted but I was only trying to get it out through curiosity.
21 Sep 2010 13:57 #4774
Replied by mlines on topic Re:Bend, Cut or Weld ?
Its Able Motor Services, Lands End Stables, Park Lane, Charvil
0118 934 3713
He is an ex-Comp Safari racer. Bit of a scruffy, run down sort of place which is therefore good for quick, cash based, favours.
My lever was out and its only a short walk from my house. He gave it a quick heat and a bend. I would have thought it would also be pretty quick to do it with the car there as well if you remove the plates and gaitors before you set off.
- ooky_123
21 Sep 2010 14:26 #4775
by ooky_123
Nice one. I assume the stick is just a bayonet fitting into the housing. Ill have a look this weekend into getting the gator off.
21 Sep 2010 16:33 #4780
If I remember correctly it has a metal ring around the outside that needs pushing down and turning to release the lever.
If you do arrange to come over check if I am around and we can have a coffee.
26 Sep 2010 19:00 #4836
by kirkynut
Mine had a ring to press down and turn to release as Martin says after you unbolt the plate above held in by the 3 bolts I mentioned. However, even with the box on the workshop floor I couldn't get it out. I span it all the way round pushed down but it did not release.
That must be the way to do it but I think I couldn't have pushed it down far enough. The spring under it had a lot of pressure behind it, making it difficult and it will be more so in the car.
You may be less of a Jessie than me though!
Hope you get it out ok.
Time to create page: 0.324 seconds
