Bend, Cut or Weld ?
  • ooky_123
20 Sep 2010 16:56 #4755 by ooky_123
Bend, Cut or Weld ? was created by ooky_123
one major flaw of the recent body lift is the gear selector will not go into 4-low.
I was wondering how others have overcome this issue ...
20 Sep 2010 17:15 #4756 by mlines
Replied by mlines on topic Re:Bend, Cut or Weld ?
I hunted around for a workshop that still had gas rather than MIG and they applied a lot of heat to bend it easily
  • ooky_123
20 Sep 2010 18:54 #4758 by ooky_123
Replied by ooky_123 on topic Re:Bend, Cut or Weld ?
Thats good to know Martin. I'll have a look around the local area for a fabricator / garage that has an oxy torch
  • Jamie
21 Sep 2010 08:58 #4765 by Jamie
Replied by Jamie on topic Re:Bend, Cut or Weld ?
You can do it with a tig welder too, that's how I did mine, just flatten
The tungsten and about 60amps heats it up nicely!!!
  • ooky_123
21 Sep 2010 13:17 #4768 by ooky_123
Hmm not having access to any welder, Gas, Arc or MiG/TiG this is an issue for me.
I need to take a trip to my local garage to see if they can help me, or failing that, I may be off on a road trip to KAP with a bag of cash to ask them for help.
21 Sep 2010 13:21 #4769 by mlines
Don't bother going all the way North (unless its for the BigJimny meet at Tong!!)
If you are prepared to travel a bit then I can point you at the local mechanic near me who heated mine up for beer tokens
Time to create page: 0.171 seconds
