2000 Jimny Water Pump Generator belt adjustment.
- Crumbley
16 Nov 2012 14:36 #53433
by Crumbley
2000 Jimny Water Pump Generator belt adjustment. was created by Crumbley
Hi Everybody,
This may be a silly question, but has anybody tried to access the generator pivot bolts under the generator?
I can reach the adjusting bolt, but I can't even see the generator pivot bolts, never mind getting a spanner on them.
I've looked from the top and from underneath but no joy.
I only want to ajust the belt tension.
Do I need to start dismantling anthing to get access?
Suggestions apreciated.
- markyp2000
16 Nov 2012 17:59 #53448
by markyp2000
Replied by markyp2000 on topic 2000 Jimny Water Pump Generator belt adjustment.
what engine is it single or twin cam
- Crumbley
16 Nov 2012 18:59 #53462
by Crumbley
Replied by Crumbley on topic 2000 Jimny Water Pump Generator belt adjustment.
I think it is single cam engine.
- Crumbley
16 Nov 2012 19:02 #53464
by Crumbley
It's the G13BB standard engine.
16 Nov 2012 19:14 #53465
by j999pre
Grey pick up Jimny
Replied by j999pre on topic 2000 Jimny Water Pump Generator belt adjustment.
14mm bolt accessed from underneath. Socket and bar needed. Try loosening the top bolt first you may get enough movement on the generator without undoing the lower bolt if it has been done before.
Grey pick up Jimny
- Crumbley
17 Nov 2012 06:47 #53497
by Crumbley
Thank you for the response.
Is it just one 14mm bolt underneath?
Is the bolt vertical or horizontal?
I did try moving the generator with only the top bolt loosened but no joy.
I need to try to identify the bolt with a mirror on a stick.
Another old post suggests that the lower bolt needs an allen key and the radiator removed, but it maybe not for my specific engine.
Time to create page: 0.195 seconds
