auto transmission
- mvonh
15 Nov 2012 09:07 #53301
by mvonh
auto transmission was created by mvonh
HI THERE JUST WONDERING IF ANYBODY CAN SHED SOME LIGHT ON HOW THE KICKDOWN WORKS ON MY AUTOJIMNY IVE LOST KICKDOWN AND IT STRUGGLES UPHILL BECAUSE OF THIS GEARBOX IS OK FOR FLUID AND IS SMOOTH AS EVER ONLY OTHER AUTOS IVE HAD USE CABLE FOR KICKDOWN BUT NOT JIMNY ANY POINTERS WOULD BE APPRECIATED CHEERS MICHAEL
15 Nov 2012 17:41 #53329
by facade
Replied by facade on topic auto transmission
The jimny uses throttle position to select gear.
If your foot is flat on the floor and it won't change down, likely fault is with the throttle position sensor circuit.
If it is not operating all 4 gears and lockup, you may be in limp home mode, when the gearbox will not operate properly. There is a diagnostic connector, but you need a special code reader for the transmission.
You sure it isn't just down on power due to a blocked catalyst?
BTW please don't write all in capitals, netiquette (have I made up a word) dictates that this is shouting.
Time to create page: 0.193 seconds
