Wing indicator
  • jimnyonhigh
11 Nov 2012 19:50 - 11 Nov 2012 19:52 #52912 by jimnyonhigh
Wing indicator was created by jimnyonhigh
:unsure:
Hi guys
My wing indicator orange case has come away leaving the bulb exposed in the white casing. Does anybody have an idea how to remove the indicator unit away from the wing as one of the clips has come away which made the orange case fly away during a play day weekend.
Be grateful for any help, looks easy but I don't want to do any damage.
Thanks
Attachment not found
Last edit: 11 Nov 2012 19:52 by jimnyonhigh.
  • markyp2000
11 Nov 2012 19:57 #52916 by markyp2000
Replied by markyp2000 on topic Wing indicator
put an orange buld in it (501a) if you want to remove the unit take the inner wing cover off and push it out from behine after you squees the clips together
  • jimnyonhigh
11 Nov 2012 20:03 #52922 by jimnyonhigh
Replied by jimnyonhigh on topic Wing indicator
Hi thank you for the reply, one of the clips had broken so I assume the orange case had flown away or got knocked during a outing. Is removing the wing a simple job ? I ordered the hole unit as otherwise the orange cover would just fly away again unless I glued it on.
  • Smoggy
11 Nov 2012 20:17 #52927 by Smoggy
Replied by Smoggy on topic Wing indicator
The part that attaches to the orange lens (with the broken clip) unclips from the connector with the wiring going into it. Toremove the inner plastic wing guards just prise out the round plastic clip centres then the whole clip will come out, I believe there are also some small screws/bolts, all quite straightforward and easy to see.
  • Smoggy
11 Nov 2012 20:20 #52928 by Smoggy
Also the orange lens cover just pushes and clips onto the grey base unit (thats the part with the side clips on).
  • jimnyonhigh
11 Nov 2012 20:26 #52929 by jimnyonhigh
Cheers guys ill have a look when I get the unit sent to me, at first I thought somebody robbed the orange case but on close inspection I think one of the clips on the grey unit behind where the orange case should go had been broken away obviously flinging the cover away.
Cheers for your replies, amazing a simple job can come across so daunting. Used to more serious jobs!
Thanks again
Time to create page: 0.170 seconds
