No 4WD!
  • Mike1992
08 Nov 2012 12:35 #52636 by Mike1992
No 4WD! was created by Mike1992
Can anyone help me please?
I have a 2000 Jimny and it has recently stopped going into 4WD, ive had it in the garage a couple of times and they say its the 4WD switch on the top of the gearbox. But i cant find one anywhere. Can anyone suggest where to look for one.
Thanks! :laugh:
  • Mike1992
08 Nov 2012 12:56 #52638 by Mike1992
Replied by Mike1992 on topic No 4WD!
The garage shorted the swtich out and all the dash light came up so theres is a problem with it but i just cant fond one anywhere......
  • JerseyJimny
08 Nov 2012 13:16 #52641 by JerseyJimny
Replied by JerseyJimny on topic No 4WD!
Dose it the 4WD light flash?
  • markyp2000
08 Nov 2012 20:11 #52665 by markyp2000
Replied by markyp2000 on topic No 4WD!
where are you based there may be some one local to you that may be able to help also look here
www.bigjimny.com/index.php/forum/7-jimny...ght-flashing-on-dash
  • Mike1992
08 Nov 2012 22:51 #52680 by Mike1992
It used to be fine and now the 4WD light flashes but every now and then it will stay on as if it has engaged but you can hear that the 4WD pins haven't clicked into place :/
  • JerseyJimny
08 Nov 2012 22:54 #52682 by JerseyJimny
When the 4WD light flashes it mean that 4WD hasnt been engaged
Usually due to a leak in the vaccum lines
If you read the guide posted above it will tell you exactly how to do find the fault :)
Time to create page: 0.166 seconds
