lound nocking
  • deedar
04 Nov 2012 22:16 #52342 by deedar
lound nocking was created by deedar
I hit a kerb side on the other nite when it was wet and a loud clicking noise started I thought it was the CV joint so I replaced it this morning and went to freckly and got so far there and it started again just in first but I carried on and went of road for day and it has got worse it was doing it in first and second she I set off back then pals fourtrakbtoke down so I pulled I'm home and it now doing it it 1st 2nd 3rd and 4th and I have no idea what it could so any help with be sound thanks deedar
  • deedar
06 Nov 2012 17:23 #52484 by deedar
Replied by deedar on topic lound nocking
hi it it nothing to do with the front axle because i unlocked the front hubs as they were locked in all the time as the vacuum does not work and removed the front prop shaft and drove it but it is still nocking and i noticed a pool off oil on the floor coming from the rear axle and it it leaking out off the passenger side drum so any ideas on what that could i think it will be the diff seal or something like that not 100% though any help will be brill thanks
06 Nov 2012 17:45 - 06 Nov 2012 17:46 #52486 by facade
Replied by facade on topic lound nocking
You have probably bent the rear halfshaft on that side.
Jack it up and spin the wheel. It should run straight, I bet it wobbles. The knocking could be the drum touching as it goes around off centre, or the splined end flicking up and down in the differential.
You could even have bent the axle tube, but I doubt it.
Pull the halfshaft (need to to change the seal anyway,) and see if it is straight.
Last edit: 06 Nov 2012 17:46 by facade.
  • deedar
06 Nov 2012 20:16 #52507 by deedar
it was the front wheel that hit the kerb not the rear but would it make a nocking noise iff the was no oil in the and can i use old engine oil in the diff
06 Nov 2012 20:35 #52510 by facade
It will makes more noise with no oil in, but if it is coming out the axle ends, it has some in ;)
Don't use old engine oil for anything, except perhaps mixing with creosote to paint a fence :whistle: , get some GL5 EP80/90. Not too expensive from a motor factor, just buy the cheapest if you like.
Maybe there is a problem with the rear differential, odd that it would start at the same time as a front wheel hit the kerb though.
You are going to have to pull the halfshaft out on the leaky side to change the seal, you may find there is a problem with the brake on that side, or that the wheelbearing has gone.
  • ZookFastback
06 Nov 2012 20:42 #52512 by ZookFastback
Replied by ZookFastback on topic lound nocking
Maybe the impact was transferred through the drive shafts and so a uni-joint might be buggered?
Time to create page: 0.192 seconds
