blowing cold only warmish air?
- tez
03 Nov 2012 17:08 #52088
by tez
blowing cold only warmish air? was created by tez
hi im a newbie and i have just got a w reg soft top. drove it 250 miles home and no issues and it goes good except for the heating. I flushed out the system and put a new thermostat in her. ran her up for 20 mins as well as topping up anti freeze making sure all tthe air was out. seems fine but when i put fan heater on it is only warm not nice and hot. i checked bottom hose and that felt cold so im thinking next course of action is the water pump... any ideas ?
- markyp2000
03 Nov 2012 17:15 - 03 Nov 2012 17:16 #52090
by markyp2000
Replied by markyp2000 on topic blowing cold only warmish air?
still could be thermostate where did you buy it from
also it could be a blocked radiator as the water flows from top to bottom
and yes could be water pump is the water curculating in the top of the rad
Last edit: 03 Nov 2012 17:16 by markyp2000.
- tez
03 Nov 2012 17:37 #52097
by tez
Replied by tez on topic blowing cold only warmish air?
yes water flowing top of rad, in not convinced its a head gasket as i had no water loss or tempreture issues after a 250 mile drive. so im not sure what to do next
- markyp2000
03 Nov 2012 17:42 - 03 Nov 2012 17:43 #52100
by markyp2000
so where did you buy the thermostat from
is the rad blocked and not letting the water flow out the bottom hose
also what year and engine is it
Last edit: 03 Nov 2012 17:43 by markyp2000.
- tez
03 Nov 2012 17:52 #52106
by tez
i got thermo from unipart motor factors. rad not blocked as i took out plastic screw in plug at bottom of rad to assist in draining and engine is soc the spanish built soft top
- markyp2000
03 Nov 2012 17:57 #52109
by markyp2000
just because you took the bung out and it flowed out doesnt meen the rad isnt blocked remove the stat and check in a pan off boiling water and see if it opens
Time to create page: 0.089 seconds
