alignment issues
  • paumd
03 Nov 2012 07:59 #52059 by paumd
alignment issues was created by paumd
Hi guys! bought a new jimny this year and after lurking around decided to have my jimny lifted. 2 in body + 2 in susp lift + 235/75/15 tires. very happy with my decision to have it lifted. the car drives great however i've noticed that the car veers slightly to the left and when driving straight the steering wheel is a few degrees off center to the right. no signs of the dreaded jimny wobble at 100 kmh. very hesitant to have it aligned since the jimny wobble might manifest itself haha. i did notice that the one who did the lift took off the steering wheel to re-center it. any thoughts? havent gotten to adjusting the steering bar yet as i've read in the forum. BTW i've also noticed that my jimny steering wheel does a full 2 turns to the right and 1 3/4 turns to the left. Thought that the steering damper was the culprit and it was limiting the number of turns and i took it off. same thing. Didn't noticed the unequal nuber of turns when the jimny was stock
  • supergaz
03 Nov 2012 08:13 #52061 by supergaz
Replied by supergaz on topic alignment issues
Welcome to bigjimny.
Did you install castor correction bushes? Its a bad idea to remove the steering wheel to correct it. You should adjust the front steering arm to allow for its extra droop. With 2" lift you should get away without adjustable panhard rods as the axles pull slightly out of line. However a relocation bracket for the panhard rods wont be a bad idea.
  • paumd
03 Nov 2012 08:23 #52063 by paumd
Replied by paumd on topic alignment issues
no castor correction bushes yet but i have installed adjustable panhards. axles are centered already. thanks!
03 Nov 2012 08:43 - 03 Nov 2012 08:44 #52067 by facade
Replied by facade on topic alignment issues
What supergaz means is:
The drag link from the steering box to the left front wheel is too short now that the axle is further from the chassis.
Adjust it longer to put the wheel back central.
Do not remove the steering wheel.
Last edit: 03 Nov 2012 08:44 by facade.
  • markyp2000
03 Nov 2012 17:54 #52107 by markyp2000
Replied by markyp2000 on topic alignment issues
if you fitted an adjustable panard rod and puled the axle back into aline then the steering wheel would have be come straight so just take the steeing wheel back off and fit it in the straight position
03 Nov 2012 19:17 #52124 by facade
I'm afraid it wont.
The axle is in line, but 2" lower down, so the drag link needs to be extended to compensate.
Repositioning the wheel will leave it with less steering lock to the left, as the box will hit the endstop too early.
Time to create page: 0.171 seconds
