brake lights not working
- nate78
25 Oct 2012 18:02 #51247
by nate78
brake lights not working was created by nate78
have just taken my jimny for mot all went well apart from the brake lights not working! both side and middle brake lights are not working so im thinking its not the bulbs, i have taken the brake light switch off and taken it apart to look inside, all seems to be working ok, i have also looked at the fuses under the steering wheel and they look ok too, its too late now but i will get a bulb to try, does anyone know what fuse is for the brake lights? failing all that any other ideas? thanks
- markyp2000
25 Oct 2012 20:25 #51263
by markyp2000
Replied by markyp2000 on topic brake lights not working
get a bit of wire and bridge the to wires out on the brake light switch multi plug and see if thay come on if not it should be marked on the fues box cover
- rs200boy
25 Oct 2012 20:50 #51267
by rs200boy
Replied by rs200boy on topic brake lights not working
as above ive checked many a switch and found it to be all working fine then when plugged in it doesnt so as above bridge it out rule out the switch alltogether
- nate78
25 Oct 2012 21:55 - 25 Oct 2012 21:57 #51270
by nate78
Replied by nate78 on topic brake lights not working
i tried the wire trick but still didnt work, i decided to find which fuse was for the brake lights and took it out, at first glance it looked fine but i could just see a split in the fuse, so changed it and all fine, i was surprised to see that the fuse didnt blow at the 'weak' point, ive never seen that before, thanks for your help
Last edit: 25 Oct 2012 21:57 by nate78.
Time to create page: 0.309 seconds
