swivel joint
- Thank you received: 670
18 Oct 2012 19:27 #50735
by facade
swivel joint was created by facade
An easy job if you have a toolkit, sounds like you already know the problem as you have bought the correct parts.
See the blue bar next to the BIG JIMNY logo?
Click on the "information" then select "how to guides" and download a nice pdf of how to change the kingpin bearings.
Let us know how you get on, or if you get stuck.
- Sam_
18 Oct 2012 20:03 #50742
by Sam_
First Job I did on my jimny was the kingpin bearings, seems daunting but follow the guide first time will probably take about 3-4hours but the second set i did only took about 1 1/2hrs.
Go for it! it'll be fine
Replied by Sam_ on topic swivel joint
jimnyonhigh wrote: Does anybody know any garages in the Tadley, Basingstoke, Reading area that will work on Jimnys and fit the parts i supply to do the kingpin bearings ? I am not a Mechanic but i am slowly learning, the Kingpin bearings seem a a easy fix but it is a little daunting for me as this is my first car/toy
Time to create page: 0.143 seconds
