Coil Pack or Cam Sensor
  • Ady the Truck
09 Nov 2012 01:51 #52691 by Ady the Truck
Replied by Ady the Truck on topic Coil Pack or Cam Sensor
Marky p, thank you, I will have a go at this tomorrow when I am off nights. I have a normal multimeter. I guess thus will suffice?
Its odd. becauase I tried a compression test, and it all seemed fine, and it seems to start and run ok at first, but then gets lumpier than school custard!
  • Rob2933
09 Nov 2012 14:40 - 09 Nov 2012 14:42 #52706 by Rob2933
Replied by Rob2933 on topic Coil Pack or Cam Sensor
Just a thought but I had the same prob it was cheap petrol try putting shell v power in it and see if that makes a difference it did with me also check the lamba sensor
Last edit: 09 Nov 2012 14:42 by Rob2933.
10 Nov 2012 01:35 #52755 by kirkynut
Replied by kirkynut on topic Coil Pack or Cam Sensor
I'm thinking ignition lead from coil pack to plug. They are old with a lot of miles under their belt.
  • Ady the Truck
13 Nov 2012 15:00 #53139 by Ady the Truck
Had another fiddle this weekend, ruled out cam sensor, coil pack and leads. Definitely heat related, it gets worse as the engine gets warmer. Seems to be drinking water now, and there is moisture around the exhaust manifold/head area, at the rear of the block, on the right hand side as you look in from the bonnet. Can't work out if it is oil or water, or a mixture of diesel and water, I suspect the latter as I am using water but the oil level stays the same.
So I reckon it is the head. :(
Has anyone here changed the head gasket on a Jimny, I have searched, but haven't found a decent guide to the pitfalls and problems. Or is it better to look into a complete secondhand lump to drop in?
  • markyp2000
13 Nov 2012 18:51 #53164 by markyp2000
Replied by markyp2000 on topic Coil Pack or Cam Sensor
i hope its not a mixture of water and diesel seeing as its a petrol lol on the rear of the head is a plate held on with to 10mm bolts that blanks off a water way and there is a seal where the cam sensor goes in to that domed thing on the rear of the head that covrs the rear of the cam shaft and rocker shaft
also the head my be cracked remove rocker cover and in the center of the head there is a core plug mine cracked around there
also check the valve clearance just in case there is a tight tappet that gets tighter as it warms up due to exspansion that will hold the valve open a small amount
  • Ady the Truck
13 Nov 2012 18:55 #53165 by Ady the Truck
Thanks MarkyP, I will get the feeler guages back out when I have it warmed up....and yes, I didn't mean diesel...lol. Mind you, if I did it may have explained the misfiring!
Time to create page: 1.293 seconds
