Oil
  • Jenky
17 Oct 2012 19:32 #50616 by Jenky
Oil was created by Jenky
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationWill this oil be ok for the gearbox, transmission and diffs on my jimny?
Also will this oil be ok in the engine?
Unless there is are better oils for the job?
  • Smoggy
17 Oct 2012 19:49 #50623 by Smoggy
Replied by Smoggy on topic Oil
For the gearbox you need 75w-90 gear oil (1.3litres), transfer box same (0.9litres) and diffs hypoid gear oil 75w-90 (front 1.35litres rear 1.5litres)
  • Jenky
17 Oct 2012 20:30 #50643 by Jenky
Replied by Jenky on topic Oil
No eBay APP ID and/or Cert ID defined in Kunena configurationSorry link never worked. Here it is
  • Jenky
17 Oct 2012 20:35 #50649 by Jenky
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /mnt/Main_Volume_2/www/bigjimny.com/libraries/kunena/src/BBCode/KunenaBBCode.php on line 304. Please enable debug mode for more information.
  • Jenky
17 Oct 2012 20:36 #50653 by Jenky
Link still won't work.
eBay number is 130775138715 if you don't mind doing the work and hav a look for me please.
17 Oct 2012 20:48 #50660 by facade
Replied by facade on topic Oil
It will be fine, but a bit of overkill really, and you will need 6 bottles.
I use the extra stinky Comma 80/90 GL5 in the axles and I think I put semi synthetic 75w90 GL4 in the gearbox and transfer case.
Time to create page: 0.176 seconds
