please help me
  • Jenky
17 Oct 2012 11:53 #50553 by Jenky
Replied by Jenky on topic please help me
If your in a garage and they don't know about the kingpin bearings, my advice is to use a different garage. They Carnt do a proper job if they don't have a clue!
  • goatboy
17 Oct 2012 11:56 #50555 by goatboy
Replied by goatboy on topic please help me
Lisa, if in doubt you could always print out the following guide and take it with you to the garage. Its how to change the king pins...
www.bigjimny.com/images/documents/Changi...KingPin_Bearings.pdf
  • lisa79
17 Oct 2012 12:01 #50556 by lisa79
Replied by lisa79 on topic please help me
thank you everyone for the advice i have phoned the garage and gave them this information and have been told to leave it with them.if no joy by the weekend i will be taking my jinmy to another garage i will keep you all posted and thank you for the king pin instructions i am greatfull to you all.
  • markyp2000
17 Oct 2012 17:04 #50581 by markyp2000
Replied by markyp2000 on topic please help me
hi lisa what area are you in there may be some one on here local to you that can help more
17 Oct 2012 17:08 #50583 by mlines
Replied by mlines on topic Re: please help me
mlines wrote: If your in a garage and they don't know about the kingpin bearings, my advice is to use a different garage. They Carnt do a proper job if they don't have a clue!
I agree, if a garage cannot diagnose a kingpin bearing failure and a stuck brake piston / slider then I would be very suspicious of them
Sent from my HP Touch pad using Tapatalk
  • markyp2000
17 Oct 2012 17:38 #50588 by markyp2000
Replied by markyp2000 on topic Re: please help me
you say skids out in what way ie the back is sliding out on braking or the fronts are skiding
what brakes was replaced front or rear also did you bed them in ie no hard braking unless nessacery for a 100 miles or so
