Another flashing light
- LeeMcLaren007
14 Oct 2012 16:22 #50229
by LeeMcLaren007
Another flashing light was created by LeeMcLaren007
Hi sorry if this has already been answered. New to the site. Purchased the better half a 51 plate jimny yesterday. I have had a sj for the last 3 years and thought it was time to upgrade and treat her. Now the problem.
Engaging 4 high or 4 low we get the flashing light after about 15 seconds. Jacked one of the front wheels up with the light flashing and it only took up the back lash, so the hubs are engaging. Put back into 2 high and wheel spun so its realising also.
I've had a noses at the vac pipes and cannot see any visible splits or problems with them.
Took it out for a few hours today and everything was working as it should. Just the flashing light that's bugging me a bit.
Thanks for any help and again I apologise if this is listed else where.
Lee
Lee
- reaper
14 Oct 2012 16:37 #50233
by reaper
Replied by reaper on topic Another flashing light
Does it flash at a set rate or sort of random ?
If random flash it could be either a lose wire or poor connection on the switch in the t-box
If the hubs are engaging then i wouldnt worry the light is just an indicator it doesnt actually do anything
- LeeMcLaren007
14 Oct 2012 18:07 #50240
by LeeMcLaren007
Replied by LeeMcLaren007 on topic Another flashing light
yea its flashing at a constant rate. ok thank you for your help.
14 Oct 2012 18:18 - 14 Oct 2012 18:20 #50245
by facade
Replied by facade on topic Another flashing light
The flashing light means that the vacuum switch, located on the vacuum valve block under the battery, is not detecting a vacuum when the hubs are engaged within 15 seconds of the lever moving.
If the pipes are intact, most likely is the disengage valve is leaking.
You are lucky that the hubs are locking.
With the engine ticking over, wind down the window, and select 4wd. You should hear Clickclick very quickly. If you hear Click..................................click you have a leak, if you only hear click only 1 hub is operating.
Select 2wd, you should hear clockclock as they disengage.
If you get clickclick cloclclock, the vacuum switch is faulty, or disconnected/wire broken
Last edit: 14 Oct 2012 18:20 by facade.
Time to create page: 0.171 seconds
