Fuel pump
- Ngaire
10 Oct 2012 11:25 #49911
by Ngaire
Fuel pump was created by Ngaire
My jimny won't start due to lack of fuel getting into the engine. Could this possibly be because of a broken fuel pump? Does anyone know how to change them, where they're located and the best place to buy them off the Internet? Or could it be a blocked fuel filter?
- Paul4x4
10 Oct 2012 13:44 #49919
by Paul4x4
How did you determine it's fuel the engine isn't getting? Are you sure it's not spark that's missing or something else?
Replied by Paul4x4 on topic Fuel pump
It might be anything, fuel pump, clogged filter, broken relay or a blown fuse. The pump is located in the fuel tank, so you need to drop the tank off to be able to change it.Ngaire wrote: My jimny won't start due to lack of fuel getting into the engine. Could this possibly be because of a broken fuel pump? Does anyone know how to change them, where they're located and the best place to buy them off the Internet? Or could it be a blocked fuel filter?
11 Oct 2012 08:42 #49966
by kirkynut
I would look at the easy stuff first like the relay and fuses as you don't want to take the tank out for fun! Or try to find the wiring to the pump and put it straight to a battery to test in situ.
Also, as above. How have you come to the conclusion it's not getting fuel. Could be a failed crank or cam sensor. Have you got an eml showing?
- markyp2000
11 Oct 2012 17:16 #50001
by markyp2000
Replied by markyp2000 on topic Fuel pump
take the gear leaver plastic surround of and the parking brake lever surround off and there is some wires that go trough the floor i think the pink one is for the fuel pump also hake a look at the multi plug on the under side of the car there that wiring loom goes through
Time to create page: 0.159 seconds
