Diff or wheel bearing problem?
- goatboy
09 Oct 2012 11:48 #49809
by goatboy
Replied by goatboy on topic Diff or wheel bearing problem?
Can't help further but I would change the diff oil anyway if you haven't done it lately. Its a really easy job should only take 10 minutes (assuming you can undo the plugs!)
09 Oct 2012 12:27 #49814
by kirkynut
Replied by kirkynut on topic Diff or wheel bearing problem?
Jack the suspect side up with handbrake off, other wheels choked and axle stand under axle too.
Hold wheel at 12 o'clock and 6 o'clock and if there is more than a tiny amount of play the wheel bearing is on it's way out. Usually they oil seal leaks, assuming you have enough diff oil for it to leak! But you don't want to let it get that far as it's a safety item.
To check the shoes, remove a drum. Put new ones on if you are changing the bearings as they are cheap and have to come off anyway.
09 Oct 2012 16:02 - 09 Oct 2012 16:04 #49819
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Diff or wheel bearing problem?
Your brake imbalance could be oil contaminating the shoes on the dodgy bearing side our just a stuck self adjuster. I've just done both my rear bearings as the inside of the rear tyre showed diff oil leaking out. Done both sides king pin bearings on the front too. It should hopefully drive better when its back on the road.
Grey pick up Jimny
Last edit: 09 Oct 2012 16:04 by j999pre.
- ne-crock
09 Oct 2012 18:24 #49829
by ne-crock
Replied by ne-crock on topic Diff or wheel bearing problem?
I'm nearly 100% there hasnt been a leak, i've spent alot of time recently undermycar and after seeing a recent topic on the leak i've been checking religiously.
There is deffiantly play in my n/s wheel, and a slight pay in my o/s
i'm not going to be able to change anything other than the oil till pay day which happens to me 22 days away, i only HAVE to drive me car for 11 of those days, think it would survive 11 6 mile trips?
obviously none of you know the true state of the noises etc, just if you have an opinion on life of dying bearings?
10 Oct 2012 09:15 #49902
by kirkynut
You're asking us the impossible to tell you how long the bearing will last. There should be a small amount of play but not much.
The problem is if the bearing breaks down too much it will break it's cage and the shaft will pull through it and slide out with the wheel still bolted to it, so effectively your wheel falls off with the shaft attached!
Rear wheel bearings were the only thing I hadn't changed on mine until recently when one began to go on the M25. I got it recovered as it was too dangerous to carry on. All fixed now. It's the only time I wish I had a Landrover as they can be changed in 10 mins!
- ne-crock
10 Oct 2012 18:23 #49930
by ne-crock
I knew it was a preety stupid question to be honest, but i thought i might aswell ask,
i have no choice but to drive it, soo hopefully it will last fingers crossed, if not will be a nice walk to work at 6 in the morning!
