Diff or wheel bearing problem?
- ne-crock
08 Oct 2012 10:16 - 09 Oct 2012 10:16 #49726
by ne-crock
Diff or wheel bearing problem? was created by ne-crock
Is it important to use a tourqe wrench when tightening my diff plugs,
I dont have one and my diffs making some nasty noises so i'm dropping the oil, and changing it see if that makes a difference?
Cheers
Crock
Cheers
Crock
Last edit: 09 Oct 2012 10:16 by ne-crock.
- MWells
08 Oct 2012 10:43 #49727
by MWells
Replied by MWells on topic Diff oil change,
I didn't use one when i changed mine, just nipped it up by hand with the socket (no t-bar) and used some sealant to prevent leaks. The filler plug can be quite stubborn so try that before the drain plug.
HTH Mark
HTH Mark
- vitara_mad
08 Oct 2012 10:43 #49728
by vitara_mad
Replied by vitara_mad on topic Diff oil change,
ive never used a torque wrench ive always done it by feel & never had a problem yet
- Smoggy
08 Oct 2012 15:56 #49737
by Smoggy
Replied by Smoggy on topic Diff oil change,
According to the manual the drain plug is 27nM and the fill plug 50nM so I suppose without a torque wrench thats just nipped up on the drain and 'quite tight' on the fill with a bit of sealent on both to make sure
- ne-crock
08 Oct 2012 16:35 #49741
by ne-crock
Replied by ne-crock on topic Diff oil change,
well i never ended up changing my diff oil because i thought i'd have a jack up and look around,
and it seems the n/s wheel is making the noise not my diff, it has a wobble in it making me think its my wheel bearing,
but also when i applied my handbrake, my o/s wheel locked up along time before my n/s wheel!
any idea's i know my shoes are getting low but thats going to have to wait till pay day as i'm skint
could they have anything to do with the noise?
any help would be great
dont know if i've explained it very well
- ne-crock
09 Oct 2012 10:18 #49803
by ne-crock
Also there is a clicking sound but not on every rotation of the wheel, just every 5 seconds say, more prominant at lower speeds, that or my tyre/exhaust/snorkel cancels out the sound
Time to create page: 0.198 seconds
