SJ410 prop shaft suitable for t-box conversion?
  • Paul4x4
05 Oct 2012 17:43 #49556 by Paul4x4
I have probably three of those 410 transmission prop shafts laying around, and just one slightly damaged 413 prop, so I was thinking if I could instead use the 410 prop for the conversion. Does it fit, or is it too long? I compared the props side by side, and the 410 one is just about 1" longer than the "big block's" prop, but is that too much??
I think I'm gonna get the ORA fitting kit, and I have no idea how much space there will be left for the prop shaft.
  • vitara_mad
06 Oct 2012 17:48 #49620 by vitara_mad
Replied by vitara_mad on topic SJ410 prop shaft suitable for t-box conversion?
the 410 prop will be too long
  • Paul4x4
06 Oct 2012 19:29 - 06 Oct 2012 19:35 #49624 by Paul4x4
vitara_mad wrote: the 410 prop will be too long
It must be a tight fit then, because the length difference is so little! In that case I just have to make it fit, or find myself an intact samurai prop... :)
Here's a comparison pic.
Last edit: 06 Oct 2012 19:35 by Paul4x4.
Time to create page: 0.170 seconds
